Power supply help
BradL1305
11
So i'm looking to upgrade my pavilion 500-550na i bought a few months ago.
I want to upgrade to a GTX 960 but to do this I would need to upgrade my power supply.
Can anyone tell me if i would be able to use this power supply: http://www.amazon.co.uk/Corsair-CX750-Builder-750W-Bronze/dp/B008RJZR40/ref=sr_1_1?ie=UTF8&qid=14511...
Thank you
Maybe, but I wouldn't suggest it.
A. You dont need 750w to power a gtx 960, a good 430w PSU would work.
B. The corsair CXs are not good and best avoided do to lower quality components, there are usually better units priced similarly.
Here's some higher quality options
http://uk.pcpartpicker.com/part/seasonic-power-supply-ss430st
http://uk.pcpartpicker.com/part/xfx-power-supply-p1450sx2b9
http://uk.pcpartpicker.com/part/super-flower-power-supply-sf450p14xehx
http://uk.pcpartpicker.com/part/xfx-power-supply-p1550sxxb9
http://uk.pcpartpicker.com/part/xfx-power-supply-p1550gts3x
