He already said that, a i3 4160.What processor is being used?
It doesDoes the board even have a PCIe x 16 slot?
It should, it's not an old motherboard, so it should support modern UEFI cards.Does the Bios allow for the card used?
Already said that he should look if it's fits.Do they need a low profile card?
OEM systems don't use crappy PSU's. They use PSU's from Lite-on, Delta, Acbel, or other big manufactures.You need to answer all these questions before you go recommending someone use a graphics card in an OEM. It may work no problem, or, they may end up with a card they can't use, or it might pop the PSU and destroy all their components.
The power consumption of memory is extremely low, only a couple off watts tops.and notice that i also want to higher the ram from 4gb to 8gb
Well do you have a mini tower or midi tower?and what GTX 750Ti 2gdr5 shall i get ? (eVGA,Asus,ZOTAC..etc.) ?
Which EVGA? Do you have a link?and the eVGA one doesnt need that external power connector, right ?
A 2GB version is a bit better.and it is 2gb now 1gb ! is it okay ?
