Power supply help
Hitman_1
Commendable
Sep 10, 2016
6
Is corrsair vs 500 watt psu enough for my rig is it safe to use this psu as iam on a tite budget and i dnt plan to overlock as well my specs are:
Asus h170 pro gaming
Core i5 6600
Corrsair vengence 8gb ram
Evga Gtx 1070 nvidia
1tb mechanical drive
Thermaltake and Corsair make good power supplies, however the ones that are good lile the RMx and AXI, toughpower gold etc are very expensive. And there cheaper ones are junk. Seasonic is one of the best psu makes, the pus that i selected is a Tier 2. If you want a Tier 1 than go for EVGA G2.
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply ($74.99 @ Newegg)
Total: $74.99
Generated by PCPartPicker 2016-09-11 07:21 EDT-0400
Thanx buddy for your ans i ll definitely look at it...
Secondly can u recommend any psu from corrsair or thermal tech in 50 to 60 $ range ill appreciate that thanx
Total: $74.99
