Ok,
I have made various threads to get help with my new system that i am building.
The specs will be:
AMD 64 3200+ (Venice Core)
Epox 9NPA+ Ultra
1GB (2x512mb) Corsair Value S. PC3200 DDR
GeForce 6800GT (PCI-E)
250GB Maxtor ATA/133 Hard drive
I am looking for a decent powersupply that will power this, I am from the UK and the prices are alot higher here from what i can see. I dont want to spend more than £65, which is about $110 i think.
I have seen this particular one on Scan, what do you think?
http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=156689
Does anyone recommend a better one? Preferebly from a Uk Website so that it is possible for me to order it from their.
Thanks,
The specs will be:
Epox 9NPA+ Ultra
Thanks,
