H hi1234 Prominent May 12, 2017 2 0 510 May 12, 2017 #1 Hi guys, I need help figuring if a power supply like EVGA 400 N1 100-N1-0400-L1 400W could fit into a Hp pavilion p6803w (mid-size atx) not that good with computers.
Solution clutchc May 12, 2017 If this is your PC: https://atcostpc.com/productimages/xl/P6803W-PB-B-3.jpg ...it takes a standard ATX power supply. If the EVGA 400 N1 100-N1-0400-L1 400W Power Supply is what you want to use, it will fit. https://www.newegg.com/Product/Product.aspx?Item=N82E16817438038
clutchc Titan Ambassador Apr 22, 2009 43,156 409 131,790 May 12, 2017 Solution #2 If this is your PC: https://atcostpc.com/productimages/xl/P6803W-PB-B-3.jpg ...it takes a standard ATX power supply. If the EVGA 400 N1 100-N1-0400-L1 400W Power Supply is what you want to use, it will fit. https://www.newegg.com/Product/Product.aspx?Item=N82E16817438038 Upvote 0 Downvote Solution
