Ok today I got my new parts which is an i7 8700k and a new motherboard. So as I got everything set up and powered it on and the fans weren't spinning as well as the cpu fan but the motherboard was lighting up since its rgb. So I was thinking maybe I plug stuff in the wrong way after double checking still nothing. So I removed all cords and just left the 8 pin and 24 pin nothing but the motherboard flashes again but still nothing from the cpu. So I check the power supply and the fans are not spinning at this point I still wanted to make it was the power supply. So I put just the 8pin and 24pin in my old rig nope nothing. I was wondering if this is common that after just using that same psu it could just die by putting it in a new build. Also can it also be something or as I mentioned just the power supply.
