Power supply is it good?
TheAliGamer
30
So I am probably getting a new power supply soon since my current one is not good enough.
These are the three power supplies that i was thinking of.
XFX PRO650W
EVGA 600B
CORSAIR CX600M 600W
Can these run the: MSI GTX 760 Twin Frozr OC 2GB
And can i temporarily use a 450W for like maybe 2 months to three.
Or can my card just died completely?
PS: I am not a hardcore gamer i usually only run games on med-high settings.
Any help would be much appreciated. 😀
The XFX Pro would be the pick out of those 3 for quality - it will run that GFX (GTX760 needs a 500W minimum according to MSI)
What Brand and Model is the 450W PSU? It should do for short term, but I wouldn't stress the card or you'll likely run out of power or have stability issues. If it's a poor quality PSU, it may not even have enough stability to run the system. It's not always about the Wattage, it's how well the rails hold the voltages when a load is put on it that's important. Most PSU's perform well up to 80% load, after that is where the good are sorted from the bad very quickly.
