Power Supply Issue?
Nulti
7
Hey Community, I've been experiencing an issue that I think evolves around my power supply. Recently after pressing the on button on my PC it starts up for a split second and turns off with no power signal indicated by the green light on my power supply.
After waiting 20 minutes the PC will eventually start, however it will crash after about 5-10 minutes of use and will continually restart after that and crash again after the windows logo.
Should I buy a new power supply?
Notes:
Temperatures are usually cool accordingly to PCWizard
PC works fine after roughly 10 attempts
PC specification: (Dell XPS 8300)
GPU - Radeon 6770
PSU - 460w
CPU - i5
HDD - 1x 1tb 1x 500gb
You think I can't use another power supply with the dell? Everything seems normal like 6 power pin connected to GPU and 24 to the motherboard...
I was saying that you should check. But Blackbird has looked it up and found that it should be a standard ATX power supply. If you think so too then it makes it a lot easier to find a replacement. Try and get a good quality one. Pre-builts as a rule do not have very good quality power supplies.
Alright I'll have a look since this is a temporary computer I'm looking at cutting down the price for a power supply and $100 isn't looking too good.
So can we conclude that it is the power supply causing this issue?
No. We're going on your saying that it is. I gather you tested it or tried another?
You can check your 12v, 5v and 3.3v rail voltages in bios or using your mobo utility software. If any of them are more than 0.2V from target, I'd certainly think about replacing the power supply.
You can also test your case power switch by bypassing it on your motherboard - the paper clip test.
Closest is the 3.3v which is 2.77v is this bad?
In that case my results are very bad:
+12V Voltage : 4.19 V
+5V Voltage : 2.67 V
Processor Voltage : 2.81 V
VIN3 : 1.68 V
VIN4 : 2.78 V
+3.3V Voltage : 2.77 V
VIN6 : 2.22 V
VIN7 : 1.63 V
VIN8 : 1.63 V
