Power Supply Issue
MadMan Gaming
11
The 4 pin portion on my 24 pin wont go in all the way there 2 plastic black clips that sit on top of the 20 pin keeping the 4 pin from going in all the way from coming on the computer works and turns on but this worries me.
Any pau I had you would actually need to plug in both parts together at ones.
So basically you put both parts together and then plug it in otherwise mentioned black pins will be in the way.
Thank you this helped alot i had the same problem with my 8 pin cpu connector and i got it in by putting them side by side
