Power supply of xbox360
ovadiaitay34
80
Hello everyone . I bought Xbox 360 from USA (110V ). Now I ilive in 220v country. If I buy local 220v supplie will ot give out the same anount of electricity?
Ive made it sound complicated .
Is your 360 a newer slim model??
If so it's easy you need a slim model 220v PSU .
If its an old (phat as they are known) model then there are 3 different variations with different spec PSU's.
If it is a phat model then what does the wattage say on the psu label - it will be 150/160 or 175w.
No but you need to make sure the 220v PSU you buy has ample power for your model 360 because there are 4 different models including the slim.
Comparable models are the same no matter what
Country, just the PSU has a different input voltage , not a different output voltage
I need to make sure what , I didn't understand, sorry.
