Power Supply Options
Miles Z
19
Hi all, I am doing a computer build and need a bit of advice. I need to replace my previously ordered power supply, due to it having too low of a wattage. As far as my new one goes, I am aiming for the 850-1000 watt range and want it to be fairly affordable. Do any of you have any advice or opinions on what kind of PSU I should get? I'm using an ATX mobo with a bottom mount PSU area. Also, if any of you are interested, I am putting my old power supply up for sale. It's a Corsair CX600M
My case is a Rosewill Challenger
My mobo is an MSI A88X-G43 with a 24-pin connector and an 8-pin cpu connector
Processor is an AMD Athlon X4 760K with 3.8 Ghz operating frequency
GPU is an MSI R9 280 with 3gb GDDR5 memory
So then why won't the system boot up? I've verified that the motherboard, power supply, HDD, processor, and GPU are not defective or damaged. Also, the guy who checked out my rig said this happens to a lot of AMD users, in which they need a lot more power than you think.
