J j_1993_murray Jul 29, 2018 5 0 10 Jul 29, 2018 #1 Power supply wont start woth two pcie cables plugged in, but starts when they're not plugged in
jankerson Judicious BANNED Sep 10, 2006 7,885 140 35,640 Jul 29, 2018 #2 System specs including PSU model? Upvote 0 Downvote
J j_1993_murray Jul 29, 2018 5 0 10 Jul 29, 2018 #3 Power supply: xfx xtr series 750watt 80 gold plus modular Graphics card: gtx 1060 6gb Processor: i7 6700k Motherboard: msi z170A pro carbon Upvote 0 Downvote
jankerson Judicious BANNED Sep 10, 2006 7,885 140 35,640 Jul 29, 2018 #4 Why and were are you plugging in 2 PCIe cables? The GTX 1060 only takes one PCIe connection. Upvote 0 Downvote
J j_1993_murray Jul 29, 2018 5 0 10 Jul 29, 2018 #5 One end of the cable says psu and that goes to my graphics and the other end it split into two pcie cables that go into my power supply I thought? Upvote 0 Downvote
jankerson Judicious BANNED Sep 10, 2006 7,885 140 35,640 Jul 29, 2018 #6 j_1993_murray : One end of the cable says psu and that goes to my graphics and the other end it split into two pcie cables that go into my power supply I thought? The end that says PSU goes into the PSU, the split end goes into the GPU.... Normally one 8 Pin connection. Upvote 0 Downvote
J j_1993_murray Jul 29, 2018 5 0 10 Jul 29, 2018 #7 I've switched them over, and now my screen is coming on saying to reboot and select proper boot device. Any idea about this? Upvote 0 Downvote
jankerson Judicious BANNED Sep 10, 2006 7,885 140 35,640 Jul 29, 2018 #8 j_1993_murray : I've switched them over, and now my screen is coming on saying to reboot and select proper boot device. Any idea about this? Do you have an OS installed? Go in the bios and check to make sure the right HD is selected to boot from if so. Upvote 0 Downvote
J j_1993_murray Jul 29, 2018 5 0 10 Jul 29, 2018 #9 When on my bios and clicking the sotrage tab, it's on recognising one of my ssd's my hdd or other ssd isn't on the list, trying to find it now Upvote 0 Downvote
