Power Supply passes Paperclip test, but doesnt work on motherboard.
Jul 11, 2018
5
I managed to get the board working but for only 3 seconds, no idea how or what I did to make it happen. Have read the troubleshoot page and no luck.
Jul 11, 2018
5
I should also mention i only have the power supply and motherboard installed.
Specs (so far):
Fractal design Focus G (case)
Gigabyte AB350M-DS3H(Mobo)
EVGA 450W BT Bronze(PSU)
Could you post all your system components including model #s
Barty1884
The paperclip test merely confirms it'll turn on - not necessarily that it can adequately run a given system.
Which CPU/RAM do you have? If you have an APU or 2nd Gen Ryzen, you'll likely need a BIOS update for the motherboard before it'll function.
Jul 11, 2018
5
I have done the paperclip test, it passed. But as stated, i only have 3 parts, the mobo and psu, and case. I plan on ordering a Ryzen 3 2200G as my CPU.
USAFRet
1. You also need the RAM and CPU.
2. The paperclip test is mostly useless.
Like in your car, turning the key on and the dashboard lights come on. This says nothing about the engine.
Jul 11, 2018
5
Alright, i sti have to get the ram and cpu installed. But i dont know why the motherboard turned on without it for a few seconds.
Barty1884
If you only have the 3 parts, then there's nothing to boot.
At a minimum, you need a (compatible) CPU and RAM.
If you're aiming for a 2200G, you'll very likely need a BIOS update too.
I see you did not read the manual where it says not to connect a power source to the motherboard before installing components. Electricity build up in the motherboard capacitors could damage CPU and RAM.
By the way, the Gigabyte AB350M-DS3H motherboard needs a BIOS update before you install a Ryzen 3 2200G.
I have purchased it form Amazon, Newegg and Microcenter and none had a BIOS compatible with Ryzen 3 2200G even though they sell them as a bundle.
Similar threads
