Depends on what you mean be Chinese. If you mean Chinese as in bad quality, then yes. If you mean Chinese as in of Chinese origin, then it depends. Nearly every PSU is made in China, it does not define its quality. Tell us which unit you wish to buy, and we'll tell you if it's good or bad. Or, refer to the PSU Tier List on Tom's Hardware to see if the power supply you are buying is good or not.
http://www.tomshardware.com/forum/id-2547993/psu-tier-list.html
