Hiya everyone, first thread here since I couldn't find a definitive answer by googling (and using the search function)!
I'm currently looking for parts to plan a computer (which will be my first built), looking at around the end of the year ish to start buying, or maybe during black friday.
Anyways, I was confused about the PCI express connectors on PSUs so I did a bit of reading on them, and it seems to me that the PSU I was planning on getting, the Seasonic s12ii 620, is incompatible with the newly released AMD R9 280x, because 1 has 1x6 and 1x6+2 pin connectors while the other uses 2x8 pin connectors.
However, when I tried to search for the answer online of whether or not these 2 components can work together, the answer (in several different threads) was always "Yes." Am I missing something here? It wouldn't be surprising since I'm pretty new at all this, but it seems that these 2 components can't be used together since the connectors don't match. That and I've read that using 6 pin to 8 pin adapters is dangerous since the power draw will be higher than what the 6 pin is rated for.
So, am I just delusional/over-thinking this? Or are these 2 parts actually compatible.
Thanks in advance!
Thanks in advance!
