power supply problem
burnsizzle
14
have hp pavilion elite m9500y wich has 350 watt just wondering if i can put newer 400 to a 500 watt in it since it and old modle. dont know if newer one will fiit in old case. and old one has one fan that is in the back that blows out. not like new modle that blow down. old modle no. is 5188-2859. thanks for any help.
This is your Case Dimension :
•Height: 39.6 cm (15.6 inches)
• Width: 18 cm (7.09 inches)
• Length: 42.8 cm (16.85 inches)
So I think ATX standard PSU will fit in.
That system uses a standard ATX12V PS/2 form factor power supply unit with the following dimensions (the depth is the only dimension allowed to vary):
150mm W x 86mm H x 140mm D or 5.9"W x 3.4"H x 5.5"D
The new power supply's fan does not blow down. It pulls air from inside the case and exits out the vent holes on the back.
