Power supply problem
Jul 18, 2018
I have i7 7700k
Asus 270m motherboard
16gb ram
I want to buy zotac 1050 ti 4gb graphics card
I have WME450 cooler master amps its enough or not
Are you referring to the MWE Cooler Master PSU? If so, then I'd suggest getting a more reliable unit. In terms of wattage, you're good, in terms of quality, you're not! What sort of brands do you have access to?
Your system also looks pretty unbalanced. You should be looking at a GTX1070 at the least.
Lutfij
