G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Recently my computer sometimes won't boot up. The fans run, including the
CPU fan, but nothing appears on the monitor. Sometimes I have to try several
times before it boots up okay.
I tried:
-- Different monitor
-- Different video card
-- Different video card slot
-- Cleared CMOS settings with motherboard jumper
-- Different motherboard (I recently replaced the motherboard with a later
version of the same board to fix a different problem. The problem I'm
describing here happened with both motherboards.)
Same problem in all cases.
I began to suspect the power supply, because sometimes when it wouldn't boot
up, a strange, sort of crackly sound came from the power supply, which I
don't recall ever hearing when it booted up okay.
So I went and got an Antec SL350 power supply. But the same problem happens,
except for the strange sound -- the fans start running but nothing ever
appears on the monitor. Unlike with my old power supply, it never seems to
boot up okay no matter how many times I try.
I'm using that old power supply at the moment, but I don't trust it --
sometimes I have to try several times before it boots up okay -- and would
prefer to get the Antec SL350 working.
Any suggestions?
Motherboard:
Abit KT7A-Raid
Old Power Supply, which came with the case:
300W Power Max FSP300-60BT
New Power Supply that I'm trying to use:
Antec SL350
Video Card:
ATI Radeon 8500 LE
Many Thanks,
Greg
I tried:
Any suggestions?
Motherboard:
Abit KT7A-Raid
Antec SL350
Video Card:
ATI Radeon 8500 LE
Many Thanks,
Greg
