power supply problems
burnsizzle
14
HAVE OLD msi ms-7548 aspen-gl8e mobo LOOKING FOR 80 BRONZE OR UP PSU WITH ALL 24 PINS. NOT 24 PIN AND ONE MISSING FOR GROUND WIRE OR SOME !@#$%%. GOT 550 WATT 80 SILVER WASNT DOA JUST DIDNT WORK NEED IT OT POWER GTX 660 TRYIN TO REBUILD; MOBO NEEDS 20+4 OR 24 PIN. SEAM ALL NEW PSU COMES WITH 24 PIN WITH 1 MISSING FOR GRUOND WIRE I GUESS I NEED1 WITH ALL 24 PINS please help me, money low about to give up and go back to console. Once again just wanna finish playin w.o.w
With a pin that his motherboard won't even have a connection to? Do you even know what that pin was for or are you just saying stuff?
OP, a couple of things
1. Lay off of caps lock
2. You don't actually say what problem you are experiencing, start with trying to boot a simpler system, you have a 780G chipset so you have integrated graphics, remove the GTX 660 and try to boot the system just using the integrated graphics, start simple then build it up.
