Question ( power supply ) PSU questions and needing helping buying one
UntamableWhiskers
61
Looking for a GOOD power supply
looking for 500watts to 650 watts gold or bronze
I just want one that wont BURN down my house or short my motherboard and the other parts.
I have read so many reviews on amazon and newegg and its getting to the point im lost and not sure what to buy
Corsair RX ,RM versions
EVGA BR, BQ, G2, G3, GA, G1 ,G5 and GQ
Seasonic FOCUS 550 Gold
Don't care about modular or not
Looking to spend under $90 on one .
This would be my build below
https://pcpartpicker.com/list/RRHK3t
Thanks !!!
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor ($194.00 @ Amazon)
Motherboard: ASRock X570 Phantom Gaming 4 ATX AM4 Motherboard ($144.99 @ Amazon)
Memory: G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3600 Memory ($169.99 @ Amazon)
Storage: Intel 660p Series 1.02 TB M.2-2280 NVME Solid State Drive ($97.99 @ Newegg)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive ($49.99 @ Amazon)
Video Card: EVGA GeForce GTX 1070 8 GB SC Gaming ACX 3.0 Video Card (Purchased For $0.00)
Case: Cooler Master MasterCase H500 ATX Mid Tower Case ($113.99 @ Amazon)
Power Supply: SeaSonic FOCUS Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply ($81.99 @ B&H)
Total: $852.94
Generated by PCPartPicker 2019-11-20 23:12 EST-0500
Seasonic focus are top of the line. Made some changes for storage and memory. You’ll never notice a difference between a 660p and a 970 evo much better bang for your buck. Gskill NEO is built specifically for AMD systems and DDR 3600 is beneficial with AMD over DDR 3200.
UntamableWhiskers
61
Total: $852.94
THANK YOU! yes the other parts I already have bought and the Ramm I had is also speced for AMD ryzen also got the M.2 for $40 new at micro center
Yeah just looking for like a ranking list for power supplies cause I dont want to kill my rig.
Seasonic focus gold, Corsair TXM, Rm or RMX, EVGA Supersonic G3 are all good. I would go with seasonic myself as they are equal in cost and have the best product.
UntamableWhiskers
61
Any seasonic focus gold. Just tell me what wattage you want and I’ll link it.
Also got a question for you
I have WINDOWS on my OLD ssd
I would like TO do a CLEAN install of windows to the NVME m.2 Set to boot drive
Then i would like to bring that OLD ssd over to the new build!
Otherwise how can i bring all my games and stuff over? what would you suggest I do?
I would also have an OLD HHD I would like to bring over ( does not have windows on that )
Or should I try to put all the old data and games on a external hard drive. then wipe the old drives ( idk how to do that so a linked video would help) then plug all the new and old hard drive together in the new build. ( idk if i would bring over the old HHD)
thoughts?
Power Supply: SeaSonic FOCUS Plus Gold 650 W 80+ Gold Certified Fully Modular ATX Power Supply ($105.98 @ SuperBiiz)
Total: $105.98
Generated by PCPartPicker 2019-11-22 01:37 EST-0500
Power Supply: SeaSonic FOCUS Plus Gold 550 W 80+ Gold Certified Fully Modular ATX Power Supply ($95.99 @ SuperBiiz)
Total: $95.99
Here is a 550 and a 650. As a general rule always get PSU with 50 watts over, ex. 550,650,750. Even 500,600 are usually not good.
thoughts?
Any drive without windows can be brought right over. Personally I would reinstall all of your games to ensure they are all jiving with the new OS but you can try to bring them over without doing so.
UntamableWhiskers
61
Total: $105.98
Total: $95.99
Hey thank you
So this from amazion Seasonic FOCUS Plus 550 Gold SSR-550FX 550W 80+ Gold ATX12V & EPS12V Full Modular 120mm FDB Fan 10 Year Warranty Compact 140 mm Size Power Supply https://www.amazon.com/dp/B073GY89G5/ref=cm_sw_r_cp_apa_i_Vkf2DbCJ0XS22
Is the SAME for newegg https://www.newegg.com/seasonic-focus-plus-550-gold-ssr-550fx-550w/p/N82E16817151189
In my eyes they are not and idk what one is better to get. So many stupid little difference....
Whats Best version on amazon ? Best version on newegg ?
UntamableWhiskers
61
Thank you SOOO MUCH with it all I have ran into another issue i have posted a new thread, so my ramm ins CPU-Z is showing me my ram is not running right. i went into bios and I set it to 3200 but it comes up in task manager as that but it is not running right.
any tips? LINK below with pictures
