X xYowie Reputable Nov 23, 2015 179 0 4,710 Jan 21, 2016 #1 Is the EVGA 650 GQ 80+ GOLD ($69.99) any lower quality than the EVGA SuperNOVA 650 G2 80+ GOLD ($89.99), i want a power supply that will last a very long time with these specs: i7 6700k 16gb ddr4 2133 gtx 980 ti 120gb ssd 1tb hdd x4 120mm case fans
Solution RockyPlays Jan 21, 2016 The GQ is not quite as good as the G2 series however it is still very good and perfectly fine for your build unless you want a modular power supply.
ScrewySqrl Champion Aug 2, 2010 11,199 232 53,540 Jan 21, 2016 #2 the EVGA Supernova Gold are a Very good power supply Upvote 0 Downvote
RockyPlays Honorable Dec 16, 2014 1,384 0 11,960 Jan 21, 2016 Solution #3 The GQ is not quite as good as the G2 series however it is still very good and perfectly fine for your build unless you want a modular power supply. Upvote 0 Downvote Solution
