Power Supply Query
LilaethW
6
Guys, thinking of buying a new PC, specs below - is the power supply up to the job? Thanks!
i5 Quad Core Processor i5-4670 (3.4GHz 6MB Cache
ASUS Z87M-PLUS: m-ATX USB 3.0, SATA 6.0, XFIRE
8GB Kingston Hyper X Genesis Dual-DDR3 1600MHz XMP
2GB AMD RFadeon HD7850
1 TB 3.5" SATA-III 6GB/s HDD 7200RPM 32MB Cache
24x DVD Writer
Internal 52 in 1 Card Reader
Intel Standard CPU Cooler
450W Quiet 80 PLUS Dual Rail PSU + 120mm Case Fan
LAN Port
2 x 3.0 USB Ports/4 x USB 2.0 Ports
The specs just say 450W Quiet 80 PLUS Dual Rail PSU - the next option on the site is an FSP Raider Series RA-650 80 Plus (650W). Probably better to go with that then?
Does the site list any Corsair, Seasonic, XFX, PCP&C, Antec, Enermax, or BeQuiet 5-600 watt units? If so I would suggest one of them.
So the 'Quiet' part of the power supply in the specs doesn't mean it's a BeQuiet PS? There's a Corsair 650W Enthusiast TX650 V2-80.
I thought it would be. Pushes the price of the PC above what I wanted to spend, but never mind, better that than it not working! :) Thanks for the advice guys - I replied to a couple of you individually, so I hope you got my replies - don't want you to think i was ignoring you or anything! :)
