Power Supply Quesiton
I was pro
6
I currently have a 600w PSU
Will this be enough for
2x Radeon HD 6850 (crossfire)
3x HDDs
Z68MA-ED55 (b3) Motherboard MSI
DVD RW Drive
2x 4gb ddr3 1333
Core i5 2550k
4 fans (1x 230mm, 1x 230mm LED, 2x 140mm)
I doubt it will be enough....
If it is not enough what should I get, I was looking at a 1000w PSU from Azza that only 100 bucks
Cant readily find a brand, but its from comp usa
specs:
600w ATX PSU
Input rating 115/230v, 10a/6a,60/50hz
Output rating
red +5v 50.00a
yellow +12v 23.0a
white -5v 0.6a
blue -12v 0.6a
orange +3.3v 17.0a
purple +5VSB 2.0a
green PS-ON/AN
black GND/FRDE
Thats all the info I can see on the PSU
It's not just about watts.
A good quality 600 watt / 40 amp psu would do, your's won't.
And a low quality , high wattage psu like the Azza is pointless.
For $100 or less you can get a good quality 750w that would have the 4 pcie connectors you might need and an overabundance of power for your spec.
http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=100007657%20600014023&IsNodeId=1&page=2&bop=And&CompareItemList=58%7C17%2D341%2D041%5E17%2D341%2D041%2D12%23%2C17%2D182%2D133%5E17%2D182%2D133%2DTS%2C17%2D341%2D049%5E17%2D341%2D049%2DTS%2C17%2D371%2D051%5E17%2D371%2D051%2DTS%2C17%2D341%2D052%5E17%2D341%2D052%2DTS
