I am building a new PC, my budget is currently 1200-1300 dollars.
The Specs are as Follows:
GTX275
Phenom II 955 BE
790FX based mobo
6 gigs of DDR3
Coolermaster case with 4 120mm fans
1TB Seagate SATA HDD and a DVD-RW.
Windows 7 Pro.
The question I have is about the power supply for the rig. I currently have a Thermaltake Toughpower 850W psu that is in my current PC. I believe it is in the 62 Amp class. Will this be enough? The specs as listed eats up the $1200 I had budgeted. I really do not wish to spend the $300 or more that it will take to buy a beefier PSU but I will if I must.
GTX275
Phenom II 955 BE
790FX based mobo
6 gigs of DDR3
Windows 7 Pro.
