Power supply & R7 370
FractalXX
21
Welcome.
I'm going to buy a new gpu in the near future (possibly R7 370) and I'm not really sure how to check if the amps on the 12v in my PSU are enough for the card.
Some sites said the 370 needs ~33A on the 12v rail. Some said lower.
Firstly, how much does it really need?
Secondly, would my PSU be able to power that fully?
It's a 650W HP PSU (so wattage is not a problem), and here's the picture of it (found on google, but it's the same):
I'm not really sure what are those D, B, and M rails, CPU0 and CPU1 are self-explanatory I guess. (I have a workstation with multiple CPUs, HP xw6600)
Thanks in advance.
Your Delta made HP power supply is fine for most any GPU up to GTX 980 or R9 380X as long as it has the PCIe power cables to run power to the new GPU and as long as it's not really old and worn out.
You should be fine , the Draw of the card depends on the version they vary from Stock to the Overclocked. Now before someone chimes in and says you need to replace that supply I will say Delta makes supplies for Antec so they are not bad at all.
http://www.tomshardware.com/reviews/amd-radeon-r9-390x-r9-380-r7-370,4178-10.html This is the power draw from one of those cards, a good quality 350W would run it and the recommended is a 450 Watt supply. You can convert the Watts to Amps here. http://www.rapidtables.com/calc/electric/Watt_to_Amp_Calculator.htm
I have two 6-pin PCI-E connectors, but I'm not sure if they're 6+2, or just 6. (I haven't opened the case for a while)
Also, the motherboard is CF compatible, and I haven't made any modification to the workstation (except for more RAM and my current HD 7750), yet, so I guess it won't be a problem as it's designed for 2 cards.
