Power supply recommendation
fury0609
94
Can anyone suggest me a good power supply to get from microcenter or tigerdirect that will be able to power up 2 gtx 560 ti (only 1 for now but most likely will sli in the future), i5-2500k, gigabyte z68x ud3h, cooler master hyper 212+ (don't have yet)? If I can get a good power supply for under $70 after rebate that will power up these then that's good, if not then I might just get one at newegg.
fury0609
94
i already know what im getting if i will buy at newegg which is that.
i am really not looking for better prices, just a power supply enough for my pc and around $70, microcenter and tiger direct is near me
is cooler master a good or bad brand?
fury0609
94
well my choices are
cooler master gx series 750w 80 plus bronze $59
ocz zs series 650w 80 plus bronze $69
corsair enthusiast tx650 80 plus bronze $79
antec earthwatts green series 650w 80 plus bronze $59
which one should i get?
Cooler Master GX series that ends in -E3 is total crap and failed pretty much every review, stay clear of that along with the eXtreme Power series, both are overpriced and underperforming.
The ZS 650 is a good unit but being only $5 less than the HCG-750 and the same price after rebates makes it far less appealing. The quality is inline with the HCG but the HCG-750 is more powerful, giving you some more overhead to work with, and more power for additional upgrades in the future, along with 2 more years of warranty coverage.
Of those 3, the HCG-750 is the easy pick.
1st Choice - Antec CP-850 ... $95 .... 10.0 jommyguru rating (requires compatible case)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371024
2nd Choice - XFX Core Edition 750 ... $1000 .... 9.5 jonnuguru rating
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207016
3rd Coice - Corsair TX750 V2 ..... $100..... 9.5 jonnyguru rating
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139021
4th Choice Antec High Current Gamer .... $70
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371049
