nukemaster :
Why would and SSD fail from sleep, it is no worse then turning off the computer.
Hibernate will push more write cycles, but general sleep does not(it just uses ram).
SSD's are not HDD's, stop treating them like they are.
A SSD has a small CPU onboard along with firmware that resembles a miniature OS. They have spare DDR RAM to use as a buffer and as scratch memory for that mini OS.
Depending on the model, they will interpret the sleep command as a shut down command and power off. Unfortunately bringing them back from power off there is a chance of a BSOD happening.
I'm using a SAMSUNG 830 256GB, one of the highest rated SSD's for safety and stability. The SAMSUNG instructions specifically state to disable HDD powerdown to prevent data loss and that the drive doesn't need it. It even has a wizard application that will go through and change your power settings to prevent it from trying to shut down the SSD.
