power supply replacement dell optiplex 9010SFF
thomas_ch
I'm looking to upgrade a decommissioned Dell Optiplex 9010SFF from my workplace with a new psu that would support a mid-range(ish) low profile graphics card. So far, I haven't been able to find any replacements with a wattage over 275. Does anyone know whether they exist?
unfortunately you can not upgrade PSU, it is proprietary.
Is your case looks like this?
Your best choice in GPU is 750TI
MSI GeForce GTX 750 Ti N750ti-2GD5TLP 2GB 128-Bit GDDR5
It was reported to work on Dells with 240 watt PSU.
Thanks for your reply!
Unfortunately, that card is too high profile for that case (it's just about as high as a hand is wide). The circuit board looks like it might fit, but the metal plate with the output ports is too high.
I found another card in an older thread that is low profile enough for that case.
Thanks for your time anyway.
Cheers!
The picture just showed the full size bracket and I didn't see any mention of a low profile one in the specs. Delved into the comments, saw the mention of the low profile bracket being part of the package and it working on 200W.
I shall give it a bash once I get the system, thanks a lot!
Sorry for digging in an old thread , i have a dell 7010 sff that seems to have the exact same chassis set up as the pic you posted , just for clarifcation is the 7010 sff psu also propreitary ???
i was hoping to replace it for a be quiet! 300w tfx psu . thanks
