G
Guest
Guest
Archived from groups: alt.sys.pc-clone.gateway2000 (More info?)
I have a Gateway Performance 1700 that just ended it's 3 year warrenty
in June. The power supply is part number 6500652. It's been replaced
3 times by Gateway throughout the warrenty. The last time was in
January of 2003. The fan has started making loud noises which is the
same problem the previous ones had.
Since I'm out of warrenty now, I need to replace it with a new one.
Hopefully one that's a better quality then the ones Gateway has been
sending me. Is it possible to get one that will fit in my case
without having to make any adjustments to the case? The case is St.
Francis Mid-tower Case Revision 3 [Part #3501008].
I'd appreciate some suggestions on where to buy the power supply from.
Thank you.
Thank you.
