Power Supply requirements
_Epix_
371
Hey, im building a PC and I have some questions about the power supply requirements of my build. I will have a FX-8350 (gonna OC it) and a Sapphire R9 290 Tri-X OC, im planning to get the Cooler Master V700 PSU. Is this PSU enough for this system?
Thanks
R9 290 requires 31 Amps on the 12v rail & a 550W PSU minimum
Cooler Master V700 has 58 amps/696W on the 12v rail ( 4x 6+2-pin PCIE connectors) plenty of power & cables.
The V series is Seasonic OEM & top quality, Tier one on the PSU unit tier list - The highest quality and most stable PSUs available on the hardware market today. Highly recommended for any situation
http://www.tomshardware.co.uk/answers/id-1804779/power-supply-unit-tier-list.html
(VS series is perfectly fine as well, but not quite as a good as the V series)
Only trouble with the V & VS series is that they can be a little pricey depending on where you live, so consider other options as well. EVGA's G2 series is solid & a Tier One PSU, it's usually priced really well, if available.
Supernova G2 750W: http://pcpartpicker.com/part/evga-power-supply-220g20750xr
Supernoga G2 850W: http://pcpartpicker.com/part/evga-power-supply-220g20850xr
Yes, the Cooler Master V700 (RS-700-AFBA-G1) is sufficient to handle your system configuration including the overclocking of the CPU.
Just out of curiousity, you said that minimum was 550w, can I go for a 650w PSU with a OCed FX8350 (to save some money?)
Want to save a bit of money to get a more high end GPU
Ya, gonna consider the i5 and the GTX780, trying to save as much money as possible on these parts.
Thanks for the help :) really appreciate it, and it helps with my build too 😛
