Power Supply Requirements
AnEliteBadger
18
I am going to replace my old 400w power supply with a 600w power supply. I am wondering if there is anything that my power supply will need in order to be compatible with my motherboard.
Psu compatibility comes down to the number of cables required. High end cards have dual 8 pin power connectors and some high end mobo have an extra 4 pin power connector for oc stability. So just check if you have the required power connectors and you choose a good tier 1 or tier 2 power supply.
We can help you more if you state ur mobo model, gpu model, budget and location for the psu.
