Power Supply Selection
core16
20
So far this is my parts list... http://pcpartpicker.com/p/QL7Jqs (I'm leaving an aftermarket CPU cooler as a future upgrade unless anyone has some relatively inexpensive options).
My selected graphics card, the gtx 970 gigabyte g1, states that it needs both 8-pin and 6-pin connectors with a recommended power supply of 550 watts. I want to know if both of these two power supplies will work... Silverstone ST45SF-G or Silverstone SX600-G? I'm mostly concerned about the connectors and wattage needed. Although not as important, I would like to know their potential for overclocking (CPU and GPU) and upgrades (GPU) in the future.
SILVERSTONE SFX Series SX600-G 600W +12V 80 PLUS GOLD Fully Modular Active PFC Power Supply
Connectors
1 x 24 / 20-Pin motherboard connector(300mm)
1 x 8 / 4-Pin EPS / ATX 12V connector(400mm)
2 x 8 / 6-Pin PCIE connector(400mm / 150mm)
4 x SATA connector(300mm / 200mm / 100mm / 100mm)
2 x 4-Pin Peripheral connector (300mm / 200mm)
1 x 4-Pin Floppy connector(300mm / 200mm / 200mm)
that power supply is WAY overpriced here are 2 solid top quality psu's that will work fine for the system and are MUCH cheaper http://pcpartpicker.com/parts/compare/evga-power-supply-120g10750xr%2Cseasonic-power-supply-m12ii620bronze/
both will have the needed connectors and the ecga has enough to sli the 970 no problem.
But do those two PSUs include the necessary connectors for my graphics card?
Connectors
