Hello-
I'm having issues with my new computer build. I've followed some threads here and tried different things including bread boarding.
This is the case and power supply combination:
iStarUSA D-2PFS 750W Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16811165103
The eight picture shows the case opened, which may be useful in understanding what is occurring. In addition, I am using a MB Asus P5Q, G-Skill Ram, and two solid state hard-drives.
The power supply is basically shutting down instantly. When I built the system outside of the case, all is good. I've installed the motherboard using the silver standoffs supplied with the case. This, the CPU, Power Supply, and Video Card will power on and spin in the case.
If I install the DVD drive into the cage shown and connect the power, the system will not turn on. The DVD drive outside of the case is not an issue. The same thing is occurring with my Solid State Drives. Outside of the case is no issue. Inside the case, touching the base, no-go. In fact, in one instance I heard a crackle or pop between the power connector and one 16gb SSD. This produced an intense electrical smell that still remains on the SSD hours later. I haven't an opportunity to check it yet, but feel it may be toast.
I've also purchased brass standoffs which are the same height. While they look exactly the same when held next to the silver supplied one, the screw itself is a tad larger. The store bought brass standoffs will not fit in the case.
I am confused as to why the Mobo is not shorting the power-supply, even with the CPU, Ram, Video Card in place, but the DVD and SSD is shorting the power supply. Again, this isn't a power amount issue, as it all works outside the case. 750W is more than enough juice.
I'm placing the DVD in the cage shown in the upper right side of the 8th picture. I'm placing the SSDs in the lower left.
Please post any insights or suggestions you may have. I may have to bite the bullet and take it somewhere with diagnostics, but money is tight at the moment with our family.
Thanks-
Thanks-
