Power Supply Size Issue and Good Case Fans
Rockstar525
36
I'm having trouble picking the right size power supply for this setup also would be interested in some good case fans for the NZXT 410.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($219.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($26.98 @ OutletPC)
Motherboard: ASRock Z87 Extreme4 ATX LGA1150 Motherboard ($134.99 @ Newegg)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-2133 Memory ($109.99 @ Newegg)
Storage: Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive ($122.99 @ SuperBiiz)
Video Card: EVGA GeForce GTX 970 4GB Superclocked ACX 2.0 Video Card ($329.99 @ NCIX US)
Case: NZXT Phantom 410 (White) ATX Mid Tower Case ($74.99 @ NCIX US)
Operating System: Microsoft Windows 8.1 OEM (64-bit) ($86.98 @ OutletPC)
Wireless Network Adapter: TP-Link TL-WN881ND 802.11b/g/n PCI-Express x1 Wi-Fi Adapter ($17.98 @ OutletPC)
Keyboard: Corsair K70 RGB Wired Gaming Keyboard ($152.69 @ NCIX US)
Mouse: Corsair Raptor M45 Wired Optical Mouse ($59.00 @ NCIX US)
Mentioning a good brands wouldn't hurt either! - Thanks!
Any ATX power supply will work - you have an ATX case. If by "size" you mean wattage 550W and higher will be sufficient. I recommend the XFX TS 550W power supply. Going a bit higher also never hurts if you are doing heavy overclocking. I also recommend you get a Z97 motherboard - Z87 is the older type.
Thanks for the info! :)
So going a little higher on watts wont hurt anyting?
Nope it will be just fine. For the motherboard I agree with turkey get a Z97 board heres a couple good options that cost less(and imho are better than the asrock).
http://pcpartpicker.com/part/gigabyte-motherboard-gaz97xgaming5
http://pcpartpicker.com/part/gigabyte-motherboard-gag1sniperz97
