Hola,
My power supply seems to keep voltage on the 12v and 5v rails during sleep (S3) and shutdown. Long story short, the fans (which are connected by a molex though some are controlled by Mobo) stay on when I put the computer to sleep and when I shut it down.
What exactly controls the PSU's functions during sleep/shutdown? Why would it keep power to the 12v and 5 v molex connectors?
Here is the fun part. This set up worked flawlessly until I reinstalled a clean Windows 7. So I know it can power down the molex power. Even more fun part: it occasionally works normally but once woken up, it cannot put the fans asleep again. It is completely random from what I can tell.
I've tried adjusting so many settings with no luck. I've switched just about ever Bios option I can think of.
Is it a power supply issue? Motherboard? Software? Doesn't make sense to me. It worked fine, then didn't, and I am not sure what changed.
Mobo: DFJ LanParty Jr. P45-T2RS
PSU: SevenTeam ST-850 Z-AF
Any leads would be greatly appreciated.
UPDATE: This morning, the unit went to sleep perfectly (very quickly too I might say). I checked the voltage and 12v and 5v were off on the molex connector. It worked perfectly until I shut the unit down. The computer powered down normally, but the PSU and fans continued to run. After booting, the same problem exists. What changed?!!?
UPDATE 2: I have reason to believe heat might be a factor. Things were working fine for a bit, but after playing a game for a while and bringing the temps up, I tried to put the computer to sleep and the 4 pin fans went full blast, others stayed powered as well.
