I am having a problem with my CORSAIR CMPSU-650TX 650W power supply. At least I think it's a problem.
I have been getting weird squealing noises coming from my power supply under certain load. The sounds are not that loud, but they are definitely noticeable. It makes different pitch sounds and sounds like a faint grinding/squealing. I recently plugged in a kilawatt meter and noticed that the sounds only happens when the power supply is in the 150-179 watt usage range. It turns out that my PC idles at 140 watts and when the disk and CPU are being used together under load the sound happens. So, this tends to put the watt usage right smack dab in the middle of this range under these conditions. Otherwise, I don't really hear the noise because the usage is either above or below that range.
This has been going on for over a year and have recently begun having issues with my graphics card, so I wanted to see if this is something that is abnormal or normal. The PSU hasn't failed on me yet, but I have had some weird errors and system restarts so I wanted to see if this indicates a problem with the PSU that I should be concerned with or not. Please let me know.
Thanks for the help!
