Hi,
I'm building a new PC and the case i'm using is the NZXT Phantom. Because it's a full tower case, i heard people saying that they have difficulty wiring their PC up because the cables of the PSU are too short to reach all the way across (behind) the case.
I wanted to know if anyone can suggest a good PSU that can go well with Phantom or any other full tower case. The GPU i'm using is the Radeon 7950 so i need at least a 500W PSU with 2 6pin connectors. I really dont intend on crossfiring to be honest but i will likely OC the card.
So far this is the PSU i have but i feels like overkill:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139030
thanks i appreciate it
