There are some motherboards that monitor the power supply voltages and reboot / shut down the PC to avoid damage. Many times those "surges" are false positives but you can't measure them without proper (and expensive) equipment so i recommend buying a new quality power supply in the 500-600 W range (i presume overclocked CPU and one GPU). Cheap PSUs can cause instability or even damage your system.
