Power Supply/ System Fan
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
G
Ah the wonderful world of pre-built PCs, they really don't invest much in quality components do they?
Alright, from that page it says it was using a, seemingly, unbranded 350w supply, which seems about right given the specifications of the rest of the machine.
All you will need to do is buy a replacement equal to, or larger than that, which shouldn't be too difficult to find.
Normally I would be saying invest in a quality supply, but for that system - and its demands, as well as its near-soon need of an upgrade, I suggest something basic like the Corsair VS350.
http://www.corsair.com/en-gb/vs-seriestm-vs350-350-watt-power-supply
From the looks of it, I don't think your board even requires a CPU power cable, certainly not one...
From the looks of it, I don't think your board even requires a CPU power cable, certainly not one for the GPU. To install it, it should just be a case or unplugging the old 24-pin cable and fitting the new one.
Good luck!
