BaseCrunch Aug 20, 2021 4 0 10 Aug 22, 2021 #2 Power supply is "Thermaltake SMART 600W ATX 12V V2.3/EPS 12V 80 Plus Certified Active PFC Power" btw Upvote 0 Downvote
Ralston18 Titan Moderator Oct 11, 2014 39,461 4,408 146,290 Sep 7, 2021 #3 This power supply? https://www.thermaltakeusa.com/smart-600w.html According to the specs the PSU does not provide -5 volts. And probably -5 volts is unnecessary. Reference: https://github.com/necroware/voltage-blaster However, that all said I would be remiss if I did not ask "do you need -5 volts?" Upvote 0 Downvote
H hotaru.hino Glorious Sep 1, 2020 9,805 3,567 46,090 Sep 7, 2021 #4 The -5V rail was deleted in the 1.3 version of the ATX spec. It was originally used for the ISA bus. Upvote 0 Downvote
DSzymborski Curmudgeon Pursuivant Moderator Nov 19, 2010 21,205 5,331 106,640 Sep 7, 2021 #5 Yup, the two questions I have are: Do you actually need -5V power? Is this a cheap enough machine that you really want to use it with this power-supply-shaped object? Upvote 0 Downvote
