I understand that this question has been answered many times but I cant seem to get across the proper forum that completely answers my question.
Aside from the introductions I had recently purchased a new Asus Nvidia Geforce 750ti and bought a cheap Logisys 480W PSU to try and support it. The psu came in and i had not realized i had the correct components. I had 2 molex pins to power a gpu.
My question is that is it safe to run a single or a dual molex adaper to a 6pin pcie to power my gpu. Ive been reading over forums and read multiple responses of it being okay to just use a single adapter. Only to use a dual adapter. And to just get a brand new psu with the components.
I am fine with returning the psu but not with burning down my house.Here are links to the Psu and the Gpu and the different adapters.
https://www.asus.com/us/Graphics-Cards/GTX750TIOC2GD5/specifications/
http://www.geforce.com/hardware/desktop-gpus/geforce-gtx-750-ti/specifications
http://www.logisyscomputer.com/viewsku.asp?SKUID=PS480D&DID=powersupply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817170014
http://www.newegg.com/Product/Product.aspx?Item=9SIA6J32GD7442
http://www.newegg.com/Product/Product.aspx?Item=N82E16812200106&nm_mc=KNC-GoogleAdwords-PC&cm_mmc=KNC-GoogleAdwords-PC-_-pla-_-Cables+-+Internal+Power+Cables-_-N82E16812200106&gclid=Cj0KEQjwxLC9BRDb1dP8o7Op68IBEiQAwWggQGVziuUX4Kn6aqHqIyIo1EwVLSRZ3FaEcgBu-Ot6sHgaAipP8P8HAQ&gclsrc=aw.ds
Thank you for the answer!!
