power supply torx screwdriver size
shanetemple14
446
i have just bought a brand new power supply and i was wondering if there was any way i can check what size torx screwdriver i need to remove the screws for the old power supply
Just go to your local big box hardware store, and buy a set that has multiple sizes. The right one will be in there.
Don't just get *a* single bit.
