Last night I had a weird issue, and I think it is the PSU. Before yesterday the system was in the below configuration was functioning without issue for over 6 months. I added two 12” LED strips and replaced a stock fan with a cougar fan. The system turned on for about a second and shut off, and kept going through this cycle. The LED indicators on the motherboard showed that the last test was the memory test. I removed the LED’s and both sticks from the second RAM channel and it worked, put them back and same failure. I then removed the 2nd channel RAM, and put it in channel 1 slots leaving 2nd channel vacant (to see if RAM was bad). It worked. Now I’m thinking it’s the memory slot, so I put the memory originally in channel 1 into the vacant channel 2 slot, and it worked. So I plugged in the LED’s, and same failure (on for a second, reboots after pause). When I plugged in the LED’s they are off the same molex connector, so I moved on of the LED’s to another molex connector (off the same wire though) The system boots fine with everything connected. I dried a video game for a couple of minutes to make sure it worked fine under load and all was ok. I am not sure what caused this problem or if I should be concerned. I apologize if this is worded confusing.
Corsair C70 Military Green (Green) ATX Mid Tower
Asus Z87-A ATX LGA1150
Intel Core i5-4670K 3.4GHz Quad-Core with stock cooler (I have a 212 evo on the way)
2x Stock corsair 120mm fan
1x Cougar vortex 120mm fan
4x G.Skill Sniper Series 4GB DDR3-1866
Samsung 840 EVO 120GB 2.5" SSD
Western Digital 1TB Blue 3.5” HDD
Sapphire Radeon HD 7950 3GB 384-bit
Cooler Master 500W ATX12V 80+ Bronze Active PFC
TP-Link TL-WN781ND 802.11b/g/n PCI
Microsoft Windows 7 Professional (64-bit)
