A ayushrustagi Reputable Sep 12, 2015 315 0 4,780 Sep 5, 2016 #1 Can i put a gpu in pc even if power supply doesn't have 6 pin connector ?
Solution bignastyid Sep 5, 2016 That gpu requires a 6-pin connection to function. You likely need to buy a new psu with the proper connections for the system.
bignastyid Titan Moderator Jun 19, 2011 33,654 1,674 159,590 Sep 5, 2016 #2 Depends on what gpu you want to install. To give you a proper answer we need more info like system specs and what gpu you want to install. Upvote 0 Downvote
A ayushrustagi Reputable Sep 12, 2015 315 0 4,780 Sep 5, 2016 #3 I am going to install gtx 1060 mini on b 75 m-d3h mobo..my power supply dosent have 6 pin connector...is there any solution because i have already bought gpu and the display is not coming on screen...? Upvote 0 Downvote
bignastyid Titan Moderator Jun 19, 2011 33,654 1,674 159,590 Sep 5, 2016 Solution #4 That gpu requires a 6-pin connection to function. You likely need to buy a new psu with the proper connections for the system. Upvote 0 Downvote Solution
bignastyid Titan Moderator Jun 19, 2011 33,654 1,674 159,590 Sep 5, 2016 #5 Dont bump posts. Its not allowed and we are volunteers and getting impatient is not going to get you far. http://www.tomshardware.com/forum/id-2083471/read-forum-rules-styling-posts.html Upvote 0 Downvote
