Power supply unit
Sep 24, 2018
19
I have got gt1030
It says the minimum psu should be 300w for GT 1030.
I have Intel Pentium dual core e5700 processor
4gb ram
And 3 fans
So my question is I have an iBall sps 252 (which is 250w psu I guess) .will I be able to use GT 1030 with is psu .(my doubt is that on the back of box of GT 1030 it says the power supply is 300w based on pc with i7 processor . ) Since I have low spec will there be any problem ?
Note :
I will buy vs450 soon but for 1 or 2 week will my current psu work properly ?
Thank you
Shouldn't be... as I said earlier the tdp of the graphics card is really low. But changing it sooner, the better will be.
I saw it run on 230W Dell Optiplex PSUs. I cannot guarantee that it will... I wouldn't use it with any graphics card(it's a very low quality unit).The GT 1030 has a tdp of 30W, so in theory it should work.
You should upgrade that as soon as you can.
