power supply upgrade
Nate Helms
274
hello i was wanting to upgrade the power supply in me dell optiplex gx620 mini tower i was wanting something over 400w any suggestions???? thanks
Most of the 'DELL's of the world have custom sized PSUs which are designed to fit in the spaces that they fit in. As such - a standard PSU will likely not fit into that same space. That leaves you with two options. Find a replacement based on the current model number and size of your PSU or purchase a new case and PSU and move the guts over to the new box.
You should be able to get the model number off of your PSU and do a quick google search. From that - you will get the exact size and see if you can find what you are looking for. Based on this - you won't have many options for a quality manufacturer (as you would with a standard PSU) - but you may be able to find something that will work.
The second option is prefered - as you...
The second option is prefered - as you will be able to get the quality that you should have from manufacturers such as Seasonic, FSP, Zippy or Superflower. Additionally - since DELLs (and others) are so tightly packed, you will have better airflow and longer life of your existing components.
If the size of your current PSU is actually standard - then you simply need to purchase a quality PSU from the manufacturers above and re-wire your DELL.
Good luck.
UPDATE: Seems this thread shows that it can use a standard PSU:
http://www.tomshardware.com/forum/210472-28-replace-dell-optiplex-gx620-305w
Read this and find a PSU made by the manufacturers above:
http://www.tomshardware.com/reviews/power-supply-psu-brands,3762.html
you could simply replace what you have with newer fans that have high CMF.
Alternately you can take off the side cover and cut/drill a hole for a new fan - aim for 120mm or higher.
The next best option for better airflow is to take one of my original suggestions and buy a new case. the Antec 300 is a clasic - and it has good airflow. there are also some HAF models from Coolermaster (one looks like a milk carton - which I own) and they all have High Air Flow.
