Power Supply Upgrade!!
Simu
191
do i need psu upgrade for the following system:
core i3-540 (3.68ghz)
gigabyte h55m-s2
samsung 1TB
corsair 8GB 1600mhz (2x4gb)
LG dvd-rw
3x usb devices
sapphire hd 7750
and one more thing will cm hyper tx 3 fit with my ram sticks (corsair vengeance).
Note: my current psu is 450 watts and 17A@12V.
That system should run fine with a 450W PSU. The 7750 does not require a power connector so no need for that. What brands is it, as asked above. If it's an el-cheapo everyone is going to tell you to replace it.
The hyber TX-3 should be fine. The cooler itself is not wider than the socket, just the fan hands over so it shouldn't stick out far enough to be concerned about tall RAM. if it was a wider cooler you may have to reconsider.
Simu
191
thanks mate, you wanna say Hyper TX3 will fit with tall ram on my mobo!!
Simu
191
thanks but are you sure, will fit with Tall ram sticks. actually still confused...
take a look again...
RAM:
COOLER:
MOBO:
