Power supply, Vbat 0,00V ?? Rebooting
Alfaa
66
Hello,
My PC has been shuting down over 2 years now, when i start a videogame. At first i thought it was CPU or GPU temperature, but after trying out almost everything, i came to conclusion, that it has to be power supply's fault according to weird voltage readings.(Look at the Vbat reading.. It's 0,00V, so it's not working?)
Ask for more specific information and thanks for help!
Voltages:
Label: - Chip: - Sensor: - Sample:
Vbat - Nuvoton NCT6776F - Vbat - 0,00V
3Vsb - same - 3Vsb - 3,41V
Vcore - same - Vcore - 1,05V
VIN1 - same - VIN1 - 0,08V
+12V - same - +12V - 12,25V
AVcc - same - AVcc - 3,28V
3Vcc - same - 3Vcc - 3,28V
VIN2 - same - VIN2 - 1,70V
VIN3 - same - VIN3 - 0,86V
Ok so i pulled battery out, cleaned it and put it back in. At the startup, it recognized this change and messed up alot of stuff. First, it changed time, date... I can't see some icons, it messed up internet abit. It said google is dangerous and i had to gave permissions to procced to normal sites. At the start it had to load some components? Vbat still 0,00V. PC is more quiet though and i could be abit longer in videogame before it shut down.
I just checked SpeedFan for any voltage changes. Nothing. But i just found icon on there (crossed battery) with [???%] (I just clicked unhide and then battery)
Also youtube videos doesn't work atm and facebook chat it says it can't connect.
