Power supply will this unit be enough for my GPU
omg can you check if this is the psu i need if it is il buy it now
500w
http://www.ebay.co.uk/itm/XFX-XT500-500W-Power-Supply-80-Plus-Bronze-/182047896288?hash=item2a62e672e0:g:k6QAAOSwmmxW3vbl
or
600w
http://www.ebay.co.uk/itm/XFX-XT-Series-600W-80-Plus-Wired-Bronze-Gaming-Power-Supply-Upgrade-P1-600B-XTFR-/222055811959?hash=item33b38ecb77:g:ESQAAOSwZQxW6ZEM
please can you kindly confirm it please , will this be suitable for the gpu and also to powerup my motherboard which is model z170m-plus
i should only get xfx but not the xfx xt
kindly tell me if this is right ? confirm
should i buy this
am sorry for troubling u sir cheers. hoping if this is correct
confirm , any xfx unit is good except the xt models they are made by some chinese company, the rest is made by the awesome seasonic
ahh i se ok cheers buddy , let me find some and il post reply once again so i can get confirmation before i buy big big thanks boss
what about his
http://www.ebay.co.uk/itm/Viper-550W-80-Bronze-Active-12CM-SLi-PC-Power-Supply-ATX-Computer-PSU-Gaming-/272157327763?hash=item3f5dd74193:g:ECYAAOSwvgdW2qnU
is this any good ?
am going to buy the xfx but am browsing what does this psu look like to u any good or wat ? will this be anygood to my board
thanks alot bro , erm looking for 40gbp psu till i get paid again then il buy another one worth 200gbp depends.
for now looking for 40gbp can u help ? please
break a rib and buy the one bad actor suggested its the only power supply that meets the requirements with a clean pass for gaming.
no need to buy a psu again worth 200 pounds unless u want to have 2 graphic cards in the future. and even than u are not spending 200 pounds unless u want the BEST POSSIBLE PSU on the market.
in that case...
Power Supply: SeaSonic Platinum 860W 80+ Platinum Certified Fully-Modular ATX Power Supply ($161.99 @ SuperBiiz)
Total: $161.99
Generated by PCPartPicker 2016-05-26 19:41 EDT-0400
Power Supply: SeaSonic 1050W 80+ Platinum Certified Fully-Modular ATX Power Supply ($201.99 @ SuperBiiz)
Total: $201.99
the Xfx Ts models are they chinese models or not sir ? am trying to get good understanding whats what ,
so i now know the xt is chinese , but the TS nt sure if that is chinese or not.
thanks allot.
so xfx alone is good and the xfx ts
the rest are garbage junk right .
?love u wil get back once i find something
oh and am looking for someting above 520 watts
thanks alot boss you guys are awesome , i owe u guys a drink
