Power supply with different specs, is it bad?
tomohamdi
Hello,
I replaced a faulty power supply for router that had 9V 0.6A output with the one that has 5V 1.2A output. So far it works just fine.
I was wondering if it will damage the router in any way through longer usage.
Can I keep this power supply or do I have to change it with one that has the same specs as the original?
Actually, that might be the only thing saving him! Power is calculated in watts, and watts are voltage times current. The original power adapter is supplying (9 * 0.6) 5.4 watts of power, and the other one is supplying (5 * 1.2) 6 watts.
MikeKF
87
From what I remember the amps should only cause a concern if there is a failure in the transformer that results in more amps being drawn than normal. In this case I was daydreaming when I read about the voltage and at the same time I'm just overly cautious. My electronics studies are from the distant past, so my brain is a little fuzzy.
MikeKF
87
Yes.
